Large Selection of z9/thou Valves ,Springs,Buckets etc
Ladz continuing with the clear out,selection of valves,springs,buckets etc,valves are all z9 ,thou,as we know springs will fit z650 as well,the set of 8 on the right have some valves "tipped"one or two "clipped" on bottom.Set on left better.All came from engines i have refurbed/rebuilt in the past,cant see any valves bent,some cam shells and buckets.Would defo say at least one good set for engine rebuild,would obviously need cleaning and re seating etc,there is one new exhaust valve at the front of pics.If anyone wants the lot will take £120 plus post before i put them on ebay.The lot together will be heavy so post will reflect this.Cheers Paul J
Users browsing this forum: Google [Bot] and 24 guests
