Early Z1 Carbs
Garn 1
Early Z1 Carbs
#1 PostAuthor: Garn 1 » Mon Mar 17, 2008 10:44 am
The picture below is of a very early Carb off a Z1 (1972). Note; that unlike other 28 mm Mikuni carbs with the 17mm drain-plug, there is no rear vertical rib. I am trying to establish approximately what engine they ceased and went with the strethening rib.
It appears they were only on the Z1's for a short period. Wired George (WG) from this forum thinks they went to about Z1E-3000 odd. They are not easy to spot and I would think you would had to have an early Z to have seen them.
I am aware that they changed to the small screw type drain plugs at approx Z1E-032860 (Z1A)
Someone may have read a Kawasaki Service Bulletin or Edit on this subject. Perhaps GBH could tune in!
RegardZ.
kawamick
#2 PostAuthor: kawamick » Mon Mar 17, 2008 12:02 pm
'78 Z1R, '80 Z1RII, '76 Z2 Z750 A4, '75 Z1 AME chopper, '80 Rickman CR1000, `72 Z1, 2001 ZRX1200R
Garn 1
#3 PostAuthor: Garn 1 » Thu Mar 20, 2008 8:30 pm
Kawamick, thanks for your reply, that German site was interesting. I'll probably end up putting a bid on some of his other items. It appears as so I'm "flogging a dead horse" to find the finish date of these rare carb's. Although I must admit, I had a set installed on a later Z1 and never noticed, before a friend asked me "when did they modify them to have the rib in question".
RegardZ.
Davy Doherty
#4 PostAuthor: Davy Doherty » Thu Mar 20, 2008 10:24 pm
Garn according to Jeff's reference info they were fitted up to the 3000 range. Are you trying to pinpoint to within a few hundred or closer?
Garn 1
#5 PostAuthor: Garn 1 » Thu Mar 20, 2008 11:16 pm
Davy, whereas it would be nice to have a definitive answer, with reference to some edit/ bulletin from Kawasaki, for this utter Z-nut. I guess I will have to settle for the answer that those non-ribbed carbs finished in the 3000 range (or up to the 3000 range). Meaning, these carbs could be on an engine Z1E -03999? Which is probably good enough! but will not satisfy me if I have engine number Z1E-4200 built 12/72.
Talking of definitive answers, it has been already established that;
Vacuum nipples in head (Finished Z1E- 02179)
One piece head gasket. (Finished Z1E- 14319)
Watch for my next question on Hollow cam-shafts!
RegardZ ~ Garn
Garn 1
#6 PostAuthor: Garn 1 » Fri Mar 21, 2008 11:08 pm
Just received a personal message that Z1E-230x has the non-rib Mikuni carb. Anyone in the Z1E 3000's?
RegardZ.
RB
Mine's a triple!
#7 PostAuthor: RB » Sat Mar 22, 2008 4:55 pm
Garn 1 wrote:Talking of definitive answers, it has been already established that;
That's not quite correct? Glued, taper fit tubes were up to Z1E~01000 Then to Z1E~02173 it was the threaded tube fitting and from Z1E~02174 it was the tubed manifolds :shock: B ut Hey, what's five engines between friends :wink:
Lifes too short . . .
