Set of Keihin CR SPECIAL 37mm smoothbore carbs.
Suitable for large air cooled 4 cylinder engines Z GPz GS GSX,etc
Adjustable spacing.
In very good used condition.
Period racing carbs,CRMC eligible.
£750 cash on collection from Loughborough LE11 5AS
KEIHIN 37mm CR SPECIAL CARBS CRMC
- london calling
Jack
Re: KEIHIN 37mm CR SPECIAL CARBS CRMC
Are these still for sale as I'm thinking about doing an 1170?
Cheers Pete
Cheers Pete
Might be too big for an 1170, i have 33mm crs carbs on my 1170 and that gets bogged down at low revs. 35mm are good for top end and 33mm for low down grunt.
Rob
Rob
- london calling
Hi Pete,yes the carbs are still available.
As you are fairly local,if you want to have a good look at the carbs,that's no problem.
cheers,
Jack
cheers,
Jack
Jack
