Have any of you used these particular caliper supports from Webike on your machines ? They fit Zed front forks and allow the use of aftermarket calipers. Either AP or others of the same spacing
https://japan.webike.net/products/1522501.html PMC numbers are 75-1013-1 and -2
Its not the easiest website to understand, and having ordered the wrong items once - I would rather not want to do so again
My floating discs are the correct size at at 296mm. My mount spacing is correct at 88.9mm but I also need to know what offset if any there is on the bracket.
Alas contacting Webike does not get the result I need.
What I need to know is what they actually look like please ?
The photo is a generic image on the advert and may not refer to the exact appearance of the item ya see
As said, I have one that is incorrect ( https://japan.webike.net/products/2505255.html ) which is PMC number 75-1301 so its specifically the ones at the top I am looking to ID
