Z1 Replacement Calipers Compatible?
Blackseven
#1 PostAuthor: Blackseven » Sat Mar 17, 2018 7:33 pm
I need a pair of calipers for my Z1000A1 (calipers in front) and was planning on using a pair of the new Z1 type calipers from Saisei. I've now found out however that these aren't compatible with Z1000A1 forks as the mounting holes are further apart than on the Z1.
I was wondering anyone knew if I could swap the caliper brackets on the Z1 type calipers type calipers with a later pair like the ones below which match the fork? Anyone know if these fit early calipers?
Cheers,
Rob
