Cylinder head complete with cam caps, valves and tappets fitted. Usual small cracks between plug threads and valve seats. Head was sent to Big 4 engineering in Whaley Bridge about 15 years ago for a check over, they dismantled it, cleaned parts and reassembled it saying it was perfectly useable... again been in the garage for many years for that project that never happened, so needs a good clean and paint...
£150[attachment=4]IMG_0332.JPG[/attachment][attachment=3]IMG_0333.JPG[/attachment][attachment=2]IMG_0334.JPG[/attachment][attachment=1]IMG_0335.JPG[/attachment][attachment=0]IMG_0336.JPG[/attachment]
Z1000 Cylinder Head SOLD
Peter (ex Z1000R2 owner)
Re: Z1000 Cylinder Head
pm sent
- paul doran
Re: Z1000 Cylinder Head SOLD
Hi Paul. Yes it is..... but, I have another one which I listed with a 900 head and at the time I could only find one set of cam caps and wasn't sure which of the two heads they were off.... however, I have now found the other set so could easily build up another 1000 head if you match the caps to the correct head! I don't have any useable spare cams to try a set so if it's of interest you could have the whole lot and make up one good 1000 head and do whatever with the 900 one.....
Regards, Peter
Regards, Peter
