z1000j rear wheel central?
gsxkat
#1 PostAuthor: gsxkat » Sun Apr 01, 2018 6:11 pm
Gents,
Does anyone know if the Z1000j rear wheel is centrai in the swing arm or is there an offset? I will soon be trying to fit a three spoke triumph sprint wheel with a 180 tyre in a JMC arm but have no reference point.
Anyone with similar experience?
Thanks in advance.
Martin
8 Valve Mark
Re: z1000j rear wheel central?
#2 PostAuthor: 8 Valve Mark » Sun Apr 01, 2018 8:46 pm
i seem to remember reading a good article about this n the reference point is the centre line of the headstock should be aligned with the centre of the rear wheel giving you a true centred alignment.then sort the chain-run via offsetting 1 or both sprockets and accurate spacing.. hope it helps.. mark
gsxkat
#3 PostAuthor: gsxkat » Tue Apr 03, 2018 4:49 am
Thanks for the reply. I was hoping to make up the spacers whilst the swing arm was off of the bike.
Martin
