TAKE A LOOK - WHAT YOU SEE IS WHAT YOU GET....... NUMBER # KZT00EE0062**
GOT THE BOTTOM END & COMPLETE HEAD OFF PADDERS LAST YEAR - ITS AN ST MOTOR CONVERTED TO CHAIN DRIVE.
PADDERS BUILT IT FOR HIS OWN ZED, BUT FOUND AN EARLIER ENGINE THAT MATCHED HIS FRAME SO SOLD THIS TO ME.
BARRELS AND PISTONS ARE IN LOVELY CONDITION - 69.5mm NICE FINS, BORES IN GOOD NICK.
NEW ENDLESS CAM CHAIN & RELEVANT GASKETS THROUGHOUT - FRESHLY CLEANED & PAINTED.
COMES WITH CORRECT 32t CAM SPROCKET - INCLUDES MATCHED CAM CAPS & BEARING SHELLS & BUCKETS.
LOOKING FOR £500.00 FIRM - COLLECTION ONLY (OR YOUR COURIER FROM TA11 7AN).
Z1000 MkII ENGINE
Z1000 MkII ENGINE
Re: Z1000 MkII ENGINE
Hi Piggy thanks for all the info your motor sounds ace - I compression tested my motor cold last night and it was 135 150 150 135 so I am inclined to think that it is not needing a full overhaul. I know it's a bargain but I am going to pass on yours and probably regret it. Like you I am trying to reduce my collection and another motor would ultimately mean another frame and so on. Regards Steve
