Chrome Removal
BigZCas
Chrome Removal
#1 PostAuthor: BigZCas » Sun Apr 08, 2018 8:03 pm
Advice please.
Some of the crank cases have been chromed at some point :(
Is it just a case of giving them to a chromers and asking them to remove but not re-chrome or is there a way of removing it myself ?
I would like them to end up polished.
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
Re: Chrome Removal
#2 PostAuthor: Philippe » Mon Apr 09, 2018 4:26 am
Hi BigZCas
I know it works for steel parts. The chromer can remove the chrome from those.
If the process can be reversed with alloy parts... I don't know. You better ask the chromer. He's an expert after all.
I know it's very hard to remove it yourself ...
Good luck
Re: Chrome Removal
#3 PostAuthor: ZedHead » Mon Apr 09, 2018 9:04 am
Ask Mikey, Steve
Tonto
Re: Chrome Removal
#4 PostAuthor: Tonto » Mon Apr 09, 2018 2:09 pm
Chrome Restoration Svcs at Coventry, are going to strip the chrome off a couple of old Z13 engine cases and then mirror poilsh them for me; I dont fancy de-chroming at home, think you need concentrated Hydrochloric (Muriatic) Acid and a big container.
Cheers Tim
relisysxx
Re: Chrome Removal
#5 PostAuthor: relisysxx » Tue Apr 10, 2018 6:43 am
They did all the chrome on my a4, top job and cheaper than buying repro
Re: Chrome Removal
#6 PostAuthor: kev edwards » Tue Apr 10, 2018 8:21 am
Take it to the platers, when i done mine i used Nitric acid 69%, i was a platiing chemist and tech then.
BigZCas
Re: Chrome Removal
#7 PostAuthor: BigZCas » Tue Apr 10, 2018 9:26 am
Panic over then.
I will take them to the chrome platters :D
Thank you all for the advice.
Past 5 Years
1976 KZ1000a1, Red
