Tank Lacquer Restore?
cancunia
#1 PostAuthor: cancunia » Mon Apr 09, 2018 9:14 am
The lacquer on my A4 tank has a few blisters and some has flaked off, plus a scratch. The paint & pinstripes look ok. There's no bare metal or primer showing through so I wondered if it's possible to repair the lacquer coat, either by adding polish or some new lacquer?
hartyb
Re: Tank Lacquer Restore?
#2 PostAuthor: hartyb » Mon Apr 09, 2018 10:59 am
yes
My advise is take to a painter who will flat it back to the base coat and re do all the lacquer coats
this is wise as there will be a reason the lacquer is lifting, so if only spots are done the rest will go the same way in time
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
Z1parR
#3 PostAuthor: Z1parR » Mon Apr 09, 2018 8:41 pm
Absolutely , as hartyb says , give it to a professional painter .
We all know a bit about something :wink:
0172 . Geoff Parr
