Z1000A1/2 Swing Arm
Blackseven
Z1000A1/2 Swing Arm
#1 PostAuthor: Blackseven » Tue Apr 10, 2018 9:32 pm
Wanted; an original swing arm to suit my Z1000A1 model.
It turns out that the one I've just restored is for an LTD model and the brackets are all wrong for the A1/2 chain guard; so if anyone wants a perfect LTD swing arm, let me know.
Thanks,
Rob
KeithZ1R
Re: Z1000A1/2 Swing Arm
#2 PostAuthor: KeithZ1R » Tue Apr 10, 2018 11:22 pm
2 needle bearing or 4 ?
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
8 Valve Mark
#3 PostAuthor: 8 Valve Mark » Wed Apr 11, 2018 12:07 am
don't panic! just grind off the offending ltd chain guard mounts n fab new ones to suit! the physical dimensions are the same for z750-gpz1100 disc braked, chain driven models last time I looked.. (not unitrack obviously) m
Blackseven
#4 PostAuthor: Blackseven » Thu Apr 12, 2018 12:35 pm
Thanks mark, yes I had thought about that but was concerned about getting them in the right place. I suppose if I install the engine, swing arm, wheel and chain, it should be fairly obvious where the brackets need to be positioned. I'll give it a go. Cheers,
Rob
KeithZ1R
#5 PostAuthor: KeithZ1R » Thu Apr 12, 2018 8:36 pm
KeithZ1R wrote:2 needle bearing or 4 ?
just to clarify I have two freshly powdercoated units one had a single needle roller bearing in each side the other had two in each side, one came off a Z1R the other off of a Z1000 A1 they are identical in every other facet but as you seem to have found an aqlternative solution I will wrap them back up. :)
Keith
:bop :gom
mistaken.
Blackseven
#6 PostAuthor: Blackseven » Thu Apr 12, 2018 11:01 pm
Sorry Keith, I wrongly assumed you were enquiring about my existing LTD swing arm.
I'd be interested in one of your swing arms as it will save me having to mess about with the grinder, welder and paint. I think the A1 model used the two needle roller bearings so that one would be ideal.
I see you are in Bury which is handy as I'm not far away in Stockport. I'll PM you tomorrow.
Thanks,
Rob
