K1000/KZ1100 Fuel tap gasket/rubber
guzziman56
#1 PostAuthor: guzziman56 » Thu Apr 12, 2018 3:15 pm
Please could someone advise me which way round the fuel tap rubber gasket goes in. It's the round one with 5 holes in. One side has a groove right around the outside and the other side is flat...ish. It's been a long time since I took it apart and I can't remember. Thanks in anticipation. Roger
1976 KZ1000A1, 1981 KZ1100 Shaft+Steib TR500 sidecar (ongoing), 1942 Motoguzzi 600U, 1948 Moto Guzzi GTV, 1952 Moto Guzzi Ercole (in bits), 1953 Nimbus, 1986 Moto Guzzi V65 Lario (in need of TLC), 1988 Moto Guzzi Mk V Le Mans
guzziman56
Re: K1000/KZ1100 Fuel tap gasket/rubber
#2 PostAuthor: guzziman56 » Fri Apr 13, 2018 5:57 am
I finally used my loaf and when I looked properly I could see faint marks were the original rubber gasket sat on the tap handle flat. The grooved side goes against the tap body face.
R
