Steel box section braced swing arm
- z1000puddin
Not 100%sure what this is off of.
It looks to be either JMC or Metmachex
Not ally, it’s steel.
Has the ecentric bosses.
No bearings fitted.
It’s 231mm at the pivot
It’s 248mm inside between the wheel bosses
I assume it’s possible if a zed 1000J ??
But not sure
Looking for £65+ postsge
No bearings fitted.
But not sure
Zed til Dead
Re: Steel box section braced swing arm
That will be a Davida to fit a Z1000J, Z1000R, Z1100R or GPz1100B. Other than your eccentrics being anodised blue it's identical to the one in my J (before I modified it).
Yes Stu as Coose has just said , it's one of Mr. Fiddaman's specials .
0172 . Geoff Parr
And, it's probably the one single item that made the biggest improvement to my chassis, so £65 is an utter bargain!
- 8 Valve Mark
hi puddin i could probably utilise it mate. is the wheel spindle hole standard Kawasaki size? cheers mark..
- 8 Valve Mark
just a thought gents;didn't davida upgrade/double-up the pinch bolts for the eccentric wheel/chain adjusters?at some point? hmmm..
It uses a spindle which has a keyway and an M18 nut at each end. One eccentric has two M4 grubscrews inside to slot into the keyway, where there should be a key in the other end. It's quite a lot longer than the stock spindle, where on mine I had to space even a stock wheel though there's a possibility that mine was made for a different wheel?
Mine has single pinch bolts and has not been a problem.
- z1000puddin
Thanks Guys, What a world of knowledge there is on here
Mark,
I will check tonight & replay
Stu
Mark,
Stu
Zed til Dead
Here's a Davida Moto on my old 'J' which has twin pinch bolt arrangement.
- z1000puddin
Mark
It is 18.5mm hole , that would be to suit the M18 spindle
It has the keyway & the 2 x m4 tapped holes on the ecentric adjusters
Zed til Dead
- z1000puddin
If No Takers, I will put it on evil bay.
I am going to clear ALL the spares that I have shortly for the 1100r jigsaw puzzle that I bout as its nearing the end of the build.
I will be moving house, so everything will be going
Zed til Dead
I'm not renting a van again!!!
- z1000puddin
HA HA HA
Why not Gary, you got a very good deal the last time
Zed til Dead
