Pan Head shoulder screw
Bill Newman
#1 PostAuthor: Bill Newman » Tue Apr 17, 2018 2:56 pm
Has anyone got a 5 X 6 pan head shoulder screw - Part No 23019-028? This is one of the screws that fixes the headlamp mounting ring to the headlamp rim on a Z1A.
I would be really grateful if I can get the correct part.
Cash tokens etc waiting.
Re: Pan Head shoulder screw
#2 PostAuthor: z1bman » Tue Apr 17, 2018 3:56 pm
no longer available but this would do the job £1.75 in stock at cradley
https://www.ebay.co.uk/p/Genuine-Kawasa ... /654328557
compo z1r
#3 PostAuthor: compo z1r » Tue Apr 17, 2018 5:18 pm
https://www.ebay.co.uk/itm/NOS-KAWASAKI ... xy4dNS86OD
vint johnny has most stuff remade diffo part No's
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
#4 PostAuthor: ZedHead » Tue Apr 17, 2018 6:21 pm
compo z1r wrote:https://www.ebay.co.uk/itm/NOS-KAWASAKI-Headlight-Screws-Set-of-2-Z1-900-H1-500-H2-750-KZ900-KZ1000-KZ1300/172417997938?epid=1011845736&hash=item2824e9dc72:g:fnkAAOxy4dNS86OD
The 23019-023 in the ebay ad is still available from Kawasaki but the length is 12mm and not 6mm. Have you measured your old one Bill?
If you want to try the 023 let me know. £2.50 plus postage in an envelope :D
compo z1r
#5 PostAuthor: compo z1r » Tue Apr 17, 2018 6:44 pm
O23 is still available from Kawasaki but the length is 12mm not 6mm
eclipse hacksaw fiver :D where there's a will there's away :wink:
Bill Newman
#6 PostAuthor: Bill Newman » Wed Apr 18, 2018 9:04 pm
Thanks guys. Some responses:
Z1bman - it looks as if someone had beaten me to it, using a similar shoulder screw to the one you identified;
CompoZ1R - thanks. I missed that when I googled for that part earlier on. Now ordered and despatched.
Zedhead - the 12mm hits the outer face of the headlight ring and unless you can fully tighten the screw, it's a bugger to fit the sub assembly back in the headlight shell. It was for this reason that I realised something was wrong, when I couldn't get it apart.
Post script: this was the least of my problems when I discovered the butchered loom inside the headlamp. Now sorted except for one wire. See my new post in help!
#7 PostAuthor: ZedHead » Thu Apr 19, 2018 7:04 am
Bill Newman wrote:Thanks guys. Some responses:
Bill, did you get the one from CompZ1R's ebay link? If so, the part in the picture is the 12mm one that is still available from Kawa. Hope it works out for you.
