I have a set of 26mm z900/1000 carbs, pilot screw, non vacuum tap type for sale, they have been sonic cleaned, bench synchronized, float levels set, 1 new choke bobbin, brass fuel tees i made up, will come with original tees, one float bowl overflow pipe has been replaced can be seen in photo, stainless cap screws on tops and bowls,, they have 102.5 main jets, 15 pilots, needles are 5cn7 on groove 3, pilot screws set at 1 1/4 turns out. i bought these from another club member when i thought mine were buggered, but they have been repaired, so these are up for grabs, they have taken a couple of knocks on the outer carbs and will probably need bigger main jets as these have stateside main size in them, they in effect are ready to put on and use, when bench set there was no leaks at all, would like to cover what i paid.
Carbs 26mm
Carbs 26mm
