Z1000h Tank
alfie1
Z1000h Tank
#1 PostAuthor: alfie1 » Tue Apr 24, 2018 7:43 pm
Hi I’m looking for good rust free z1000H tank .as one I’ve got as lot of rust inside and out or any good tips best way Try and remove it.
Regards
Re: Z1000h Tank
#2 PostAuthor: chrisu » Wed Apr 25, 2018 5:54 am
They are very rare so good luck. I ended up getting one repaired as it had pin holes in it.
8 Valve Mark
Re: Z1000h Tank
#3 PostAuthor: 8 Valve Mark » Fri Apr 27, 2018 9:29 pm
try oxalic acid for the inside rust, its in crystal form n water soluble n a cupful to a gallon of water, left for 24hrs should nuke the rust, leaving a black film that can be cleaned off with solvents or high pressure water. its available on ebay about £5 a kilo..i haven't tried it yet its a tip i only got recently from across the pond.. m
alfie1
Re: Z1000h Tank
#4 PostAuthor: alfie1 » Sat Apr 28, 2018 5:42 am
Thanks I will give it a go
