Hi from North Wales
Russ
Re: Hi from North Wales
#16 PostAuthor: Russ » Sat Apr 28, 2018 11:59 am
chrisNI wrote:
Russ wrote:Got a 1000 pics of the build I could bore you to death with :oops:
You could start a thread in the Bottom Shed and let everyone see how it’s going...
Hi Chris, if there is enough interest I could start one.
A lot of the problems I had with the CBX would be similar to ones on a Z I think.
relisysxx
#17 PostAuthor: relisysxx » Sat Apr 28, 2018 6:48 pm
I'm doing things the opposite way round, just finished restoring a a4 and about to start a CBX or three, bought one from South Africa and before I knew it I had two more in bits!
Should be entertaining, i'm only used to having to lap 8 valves :)
compo z1r
#18 PostAuthor: compo z1r » Sat May 05, 2018 8:13 am
Did stick my toe into a "six" forum when I first got the bike in 2015 but some of the blokes had a major superiority complex for some reason, so pulled my toe back out :( .
Russ[/quote]
welcome russ im sure that wont happen on this forum everyone helps a some point :wink:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
