Carb Synchronizing
TIKI
Carb Synchronizing
#1 PostAuthor: TIKI » Fri Apr 27, 2018 5:18 am
Hi All,
I have a 1973 Z1 and want to sync the carbs after a good cleaning and reassembly. There is no mention in either of my manuals regarding the Fixed synchronizer cap on carb #4 , can someone explain this to me or point me in the right direction as to how this works. The manual explains setting each slide at 0.6mm-0.7mm from the bottom of the bore to the top of the notch am I doing this to #4 then matching #1,2,3, to that? Thanks Randy
1973 Kawasaki Z1 900 , 1976 Yamaha DT400C , 1971 Suzuki TM-400R Cyclone
DogsbolloxofZ1B
Re: Carb Synchronizing
#2 PostAuthor: DogsbolloxofZ1B » Sat Apr 28, 2018 4:17 pm
Yes exactly correct. No.4 is set as your master.
Make sure you follow manual and set the overall
idle adjustment correctly first that way you’ll be
able to adjust up/down uniformly around mid point.
TIKI
#3 PostAuthor: TIKI » Sun Apr 29, 2018 5:15 am
Thanks DogsbolloxofZ1B
