Z650 barrels and/or head
Crofty
#1 PostAuthor: Crofty » Sat Apr 28, 2018 8:44 pm
Building a standard Z650 engine. I have the bottom end parts, but need a good set of barrels and pistons. Also a good cylinder head. It is single row cam chain, I could use a early 750 head as long as its drilled for the top roller and has a cable tacho output.
AL MARSHALL
Re: Z650 barrels and/or head
#2 PostAuthor: AL MARSHALL » Mon Apr 30, 2018 2:58 pm
pm sent
trouble.......seek and ye shall find
www.z-clocks.co.uk
johnfinn
#3 PostAuthor: johnfinn » Fri Aug 03, 2018 7:35 pm
hi got loads of z650 engine bits/ also a z750 barrels pistons single row camchain tacho drive in cylinder head cams /
Thanks,
John
8 Valve Mark
#4 PostAuthor: 8 Valve Mark » Fri Aug 03, 2018 10:11 pm
hi, i just noticed the post. I've got a nice z650 cam cover, coils, reg/rectifier i could live without..cheers mark
Crofty
#5 PostAuthor: Crofty » Thu Aug 30, 2018 2:16 pm
Sorry for a slow response been overseas for a while. I managed to source most of the bits I need off a local, but will keep i mind what you guys have.
Users browsing this forum: No registered users and 117 guests
