More junk, er parts fore sale i mean....
- Zomerset Zed
Z1000 side panels:
These are pattern parts moulded in black self-coloured ABS. They have 3 x screw holes rather than the standard cast pegs, but they do fit the standard Z1000 (not Z1 or Z900) frame. Will need a good clean up. £30 ono
Original sprocket cover......er cover: SOLD
Slight scratch and £10 ono
Standard Z1000 cam chain tensioner:
Needs a good clean. £15 ono.
Bottom and front engine mounting plates and rear engine mount spacers. Rear plates have gone to a good home already: SOLD
£10 for lot or make me an offer for what you want.
Rear brake pedal: SOLD
Has been repaired at some point in its life, but fitted and worked ok off the original bike. £15 as its quite heavy to post.
Re: More junk, er parts fore sale i mean....
can i have the oil cover please
and whats the brake pedal off ? if its good for a Z1r or Mk2 I will have that as well
engine plats and spacers as well
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
along with some lesser makes
Z1300 A1,
KE175b, KE175F
- Zomerset Zed
It was on an A2 model. I think Z1r should be ok, not sure about mk2. Maybe someone else can advise please?
I'll send you a PM if/when we can find out.
the original sprocket cover is a clutch adjuster inspection cover been looking for one for a while and got one on fleabay yesterday
- Zomerset Zed
Yes, but did it have the all-important gear lever inflicted scratch??
Zomerset Zed wrote:the original sprocket cover is a clutch adjuster inspection cover been looking for one for a while and got one on fleabay yesterday
lol no it does not, I keep checking in case anyone had one and its just my luck to have pushed buy it now, any feedback on the pm i sent you
Hi Zomer
i sent you a pm on monday morning re the engine brackets is there any update?
derek
derek
- Zomerset Zed
I have a pm from you about the battery box but nothing mentioning the engine brackets. Harty B has said he wants them so you'll have to hang fire and if he changes his mind you can have them, ok?
My Apologies i wrote will pm on here and then followed it up with a actual pm but did not send
I had said i was intetrested in the the smaller of the two brackets (which i believe is the lower middle) and made an offer i should have said it on here
managed to get sorted from one of the other guys, apologies again for the confusion
- Zomerset Zed
Going on ebay
Are the sidecovers sold
