Even more parts fro sale
Zomerset Zed
#1 PostAuthor: Zomerset Zed » Tue May 01, 2018 8:42 am
All prices including postage to UK mainland.
Afam 18 tooth 530 sprocket to fit Z1000 spline, un-used:
£15
Kickstart, seems functional. £20 as is a bit heavy.
Kickstart shaft complete, £20
Kickstart cover. this was sprayed with PJ1 gloss engine paint as a trial. As you can see it was a disaster due to lumps, so will have to be stripped, but was vapour blasted prior, so should clean up well £10
Standard oil pressure switch housing. Same condition as above: £15
Tacho cable, seems servicable, £10 ono.
Brake pedal return spring £5
More to come......
Return to “For Sale”
