Z1000st E2 1980 ignition switch
Dunlop4
#1 PostAuthor: Dunlop4 » Sun May 20, 2018 3:13 pm
I am after an ignition switch for a z1000st. Does anyone have one for sale, or know where i can buy one?
regorsmith
Re: Z1000st E2 1980 ignition switch
#2 PostAuthor: regorsmith » Sun May 27, 2018 10:51 am
hi there,
i did have one that was knackered on my ST, so i got one from Z-Power. i think it was about 40 quid.
Simonic
#3 PostAuthor: Simonic » Sun May 27, 2018 2:32 pm
regorsmith wrote:hi there,
Hi Was that for just the ignition switch or did you get a lock set ?
Thank You
Dunlop4
#4 PostAuthor: Dunlop4 » Sun May 27, 2018 3:15 pm
I have asked Zpower if they had one and they said they do not do them. The type on my ST has a built in steering lock on it and has six wires in a block connector, as well as a separate brown wire. The key keeps falling out!
#5 PostAuthor: z1bman » Tue May 29, 2018 8:41 am
#6 PostAuthor: Philippe » Tue May 29, 2018 6:17 pm
Hi Dunlop4
all the Z1000ST bikes have a build in steering lock. If you're a handy man you can open the lock and repair it.
Mostly the lock fails if there's too much dirt in it. Inside there are a few (5 or 6) litlle, more or less rectangular parts which have a rectangular opening in the middle. These parts are kept under tension by a tiny spring. When dirt and dust accumulates inside this mechanism the springs fail to push the rectangular parts in place. If you're lucky and the parts inside aren't bend or too much worn out, you can get the dirt out by using a lock cleaning spray or brake cleaner.
Give it a try, it's worth it!
Good luck
Dunlop4
#7 PostAuthor: Dunlop4 » Tue May 29, 2018 7:20 pm
Thanks Philipe and Z1b man, i have ordered the new old stock one Germany. I just do not have the time to fiddle about with it.
