Z900 rear brake light (outage) switch
Andrew_s
#1 PostAuthor: Andrew_s » Mon May 21, 2018 9:01 am
Been looking for a NOS rear brake light (outage) switch for the Z900, this is the one that fits into a 3 wire block-connector under tank.
Have spoken with Phil at Z Power and these haven’t been available for 20 years and are generally not available as old stock (nor are repros), so most owners just leave it off. However, I’m a bit anal on this stuff. :roll:
The OEM part number is 28019-001 and the Z400 unit is 28019-002 which seems to be available in the States - does anyone know if this unit would fit?
Current Bikes:
2023 R1250 GSA
Re: Z900 rear brake light (outage) switch
#2 PostAuthor: warren3200gt » Mon May 21, 2018 9:17 am
Don't know for sure but most 70's bikes used the same unit. z650's used a slightly smaller unit but does exactly the same job with the same con block. I got a nos "Yamaha" non branded one from ebay Germany for about £15 quid inc postage. Works just fine and has the same con block.
Andrew_s
#3 PostAuthor: Andrew_s » Mon May 21, 2018 12:04 pm
warren3200gt wrote:Don't know for sure but most 70's bikes used the same unit. z650's used a slightly smaller unit but does exactly the same job with the same con block. I got a nos "Yamaha" non branded one from ebay Germany for about £15 quid inc postage. Works just fine and has the same con block.
Thanks Warren, do you happen to know the part number on the Z650 or Yam unit?
Current Bikes:
2023 R1250 GSA
#4 PostAuthor: warren3200gt » Mon May 21, 2018 12:19 pm
z650 part no 28019-001. don't know the Yam one, looked the same in the picture so took a chance and it worked out (for a change)
https://www.ebay.co.uk/itm/Genuine-Kawa ... SwLVZVtLvb
These are the KHI bikes that use the same unit
1982
650 CSR KZ650B
CHASSIS ELECTRICAL EQUIPMENT ('81-'82 H1)
1981
550 GP KZ550D (GPz)
650 CSR KZ650H
KZ550 Standard KZ550A
CHASSIS ELECTRICAL EQUIPMENT ('80-'81 A1
CHASSIS ELECTRICAL EQUIPMENT ('82-'83 A3
Police 1000 KZ1000C
CHASSIS ELECTRICAL EQUIPMENT ('78 C1/C1A
CHASSIS ELECTRICAL EQUIPMENT ('79-'81 C2
More »
1980
1000 LTD KZ1000B
CHASSIS ELECTRICAL EQUIPMENT ('79-'80)
650 Custom KZ650F
KZ1000 KZ1000A
CHASSIS ELECTRICAL EQUIPMENT ('77-'78 A1
Police 1000 KZ1000E
1979
1000 LTD KZ1000B
CHASSIS ELECTRICAL EQUIPMENT ('79-'80 B3)
650 Custom KZ650C
650 SR KZ650D
750 LTD (Twin) KZ750B
KZ1000 KZ1000A
KZ650 KZ650B
Police 1000 KZ1000C
1978
1000 LTD KZ1000B
CHASSIS ELECTRICAL EQUIPMENT ('77-'78 B1
650 Custom KZ650C
650 SR KZ650D
650 SR(KZ650D1)US
KZ1000 KZ1000A
KZ650 KZ650B
Police 1000 KZ1000C
More »
1977
1000 LTD KZ1000B
650 Custom KZ650C
KZ1000 KZ1000A
KZ650 KZ650B
1976
KH500
CHASSIS ELECTRICAL EQUIPMENT (H1-D/E/F)
CHASSIS ELECTRICAL EQUIPMENT (KH500-A8)
Andrew_s
#5 PostAuthor: Andrew_s » Mon May 21, 2018 3:09 pm
Excellent info, many thanks!
Current Bikes:
2023 R1250 GSA
PAULJAC47
#6 PostAuthor: PAULJAC47 » Mon May 21, 2018 5:08 pm
Remember Keith Ogden on here saying he had a nos one not long back...
#7 PostAuthor: z1bman » Mon May 21, 2018 9:56 pm
Andrew_s
#8 PostAuthor: Andrew_s » Tue May 22, 2018 7:23 am
z1bman wrote:https://www.ebay.ie/itm/KAWASAKI-Brake-Light-Indicator-Switch-OEM-28019-002-NEW-fits-KZ400-KZ440-Relay-/122297348052?hash=item1c797d6fd4
Thanks z1bman, there seems to be plenty of Z400 ones available in the States, but the wire colour coding is different - does anyone know if they work on the Zeds?
Current Bikes:
2023 R1250 GSA
#9 PostAuthor: warren3200gt » Tue May 22, 2018 7:54 am
I would imagine they would. Internally I would think they would be identicle and its unlikely KHI would use a different circuit to one they have on other bikes already in use. Probably just a wire colour change :?:
PAULJAC47
#10 PostAuthor: PAULJAC47 » Tue May 22, 2018 8:09 am
To my knowledge Andrew ,yes used a small one recently.think most of the Zed range use a similar unit though size differs.
Andrew_s
#11 PostAuthor: Andrew_s » Tue May 22, 2018 8:19 am
:up Thanks Paul - BTW, PM'd Keith O and waiting to hear back.
Current Bikes:
2023 R1250 GSA
cancunia
#12 PostAuthor: cancunia » Tue May 22, 2018 4:12 pm
Aha, I wondered what that bit was for...
Andrew_s
#13 PostAuthor: Andrew_s » Fri Jun 01, 2018 11:44 am
Well, the NOS Z400 brake light switch relay (28019-002) arrived this morning and I've just fitted it and it works fine; comes on with front and back brake and also flashes with the bulb removed so I'm a happy bunny and I've just ordered another one as a spare! :D
The fitting is a bit Heath Robinson until I sort out a bracket:
Andrew
Current Bikes:
2023 R1250 GSA
cancunia
#14 PostAuthor: cancunia » Sun Jun 03, 2018 1:11 pm
The bracket hangs under the RH coil mounting bolt on mine & gets in the way when you take the cam cover off. Let me know if you'd like a picture of the bracket?
Andrew_s
#15 PostAuthor: Andrew_s » Mon Jun 04, 2018 3:12 pm
cancunia wrote:The bracket hangs under the RH coil mounting bolt on mine & gets in the way when you take the cam cover off. Let me know if you'd like a picture of the bracket?
Thanks, that would be useful as I was wondering where/how it fitted.
Current Bikes:
2023 R1250 GSA
