28mm Z1R Carbs
scott
Junior Section leader
28mm Z1R Carbs
#1 PostAuthor: scott » Thu Jun 07, 2018 7:13 pm
Would anyone have a set of 28mm Z1R carbs that they might like to sell? Or know of where I might get a set?
Re: 28mm Z1R Carbs
#2 PostAuthor: Philippe » Fri Jun 08, 2018 4:35 am
Hi Scott
if you don't find Z1R carbs, you could use the carbs of a Z1000ST, they're practically the same, you only have to blank the hole on the third carb where the vacuum pipe for the fuel tap comes . They're easier to find and mostly cheaper.
My Z1R has ST carbs on and it performs very good!
Good luck!
scott
Re: 28mm Z1R Carbs
#3 PostAuthor: scott » Fri Jun 08, 2018 6:20 am
Thanks Phillipe, I’ll certainly bear that in mind!!!
Steve Cooke
Re: 28mm Z1R Carbs
#4 PostAuthor: Steve Cooke » Sun Jun 10, 2018 6:17 am
scott wrote:Would anyone have a set of 28mm Z1R carbs that they might like to sell? Or know of where I might get a set?
Might have! :lol:
scott
Re: 28mm Z1R Carbs
#5 PostAuthor: scott » Tue Jun 12, 2018 11:40 am
:lol:
