Can anyone suggest the best way to re-fit my brake pedal return spring without scratching my newly painted frame?
Just to make this quiz harder, my footrest mounting pins are seized in solid so i can't whip them out to persuade the pedal past the stop bolt bracket.
Thanks everyone!
ChrisB
Rear brake pedal return spring fitment
Re: Rear brake pedal return spring fitment
54 views and no responses. Is this the problem which will stump everyone?!
Loads of gaffer tape is how I did it...
Not tried this recently so can't offer any tried and tested solution. I have seen a method of getting the centre stand spring on by expanding it and fitting something between the coils so that it is long enough to easily fit. It was with pennies with the centre stand, not sure if you have room for that on the brake pedal, but some kind of build of small shims or washers may help.
Present
Red '78 KZ - rebuilt from engine up
Other wheels - Couple of old Guzzi's
Past 1994 - 2010
Luminous Green '78 KZ import [BLE 656S]
Past 1994 - 2010
Have not done this for a long time. Can’t remember how I did it. Apologies my memory is not what it once was. Good luck. Regards Adrian.
hook the spring on the frame first then push the lever through the spring about half way then use a piece electrical wire & loop it over the the spring drape the wire behind the lever & pull the spring down past the lever then push the lever fully home & release the spring its easier with two people
