Are there any serious things to consider, apart from any localised excessive heat
Crank Welding Advice ... Do's & Don'ts !
I wanna get me Z1000 crank welded....... I know a good Engineer, but he has no prior experience with this subject.
Mark, hopefully Steve Debben or one of the guys with more experience will give you a more comprehensive answer but you will probably want to index the rods before welding to make sure everything is straight and in line before welding. If I remember this is done by putting a tool steel rod through the small ends. Also, make sure your welder does not clamp the earth lead on the far side of the bearing of the pin you are welding as this could "fuse" the big end bearing.
Good luck.
Good luck.
- london calling
- Dark Skies
- RALPHARAMA
I didn't think that crank welding was really necessary until you started pulling really silly amounts of power out of these engine - when you start playing with super chargers or NOS etc?
At what sort of power level would welding up the crank be deemed a requirement? I always had the impression that it was only done by really manic drag racers who were really pushing the envelope
Ralph Ferrand
- london calling
