Brake squealing
Brake squealing
My front brakes squeal like a stuck pig. Tried copper slip to no avail pads are old but have life left. Maybe a change of pads to new ones would fix. Any thoughts?
Re: Brake squealing
Could have smooth patches. I wo7ld change they are cheap enough so nothing to loose
Re: Brake squealing
Jon try non sintered pads,always a problem at least you know they are working..
Re: Brake squealing
Just happy t see youre riding mate!
Re: Brake squealing
Well, I have replaced the pads, the feeder pipes as one had started to leak, new lever ( old one had an oval hole) & new fluid. Short run, no squeak. Need a good ride out but been away for work.
Re: Brake squealing
Brake squeal is always down to the pads vibrating in the caliper.
Usually caused by old pads, sticking pistons, occasionally a warped disc. It's nearly always a simple fix.
Re: Brake squealing
Taffus wrote:Just happy to see youre riding mate!
^^^This
Re: Brake squealing
Done silence reigns
