z1000 a1 mikuni carb adjuster
777 EMU
#1 PostAuthor: 777 EMU » Sat Jul 07, 2018 7:50 pm
hi
just got my 1977 z1000 a1 an upon trying to adjust the carbs with morgan carb balancer two of the screw adjusters at the top of the slides are damaged,the screw slot is worn and i cant properly adjust them.
does any one know either part number or supplier of replacements ,all my searches have proved fruitless
thanks
john
Re: z1000 a1 mikuni carb adjuster
#2 PostAuthor: warren3200gt » Sat Jul 07, 2018 8:02 pm
You could give allens performance a ring, all they do is carb and fuel line parts.
http://www.allensperformance.co.uk/shop/
777 EMU
#3 PostAuthor: 777 EMU » Sun Jul 08, 2018 10:45 am
thanks for quick response :D , will give them a try
#4 PostAuthor: z1bman » Sun Jul 08, 2018 12:16 pm
try john browse in wrexham
#5 PostAuthor: ZedHead » Mon Jul 09, 2018 12:03 pm
z1bman wrote:try john browse in wrexham
+1
Part number is 16046-012. There are a few from the states on ebay for stupid money.
#6 PostAuthor: kev edwards » Tue Jul 10, 2018 7:17 pm
This has happened quite a bit, on one set i had i cut the slot deeper and made the screwdriver narrower to enable me to do the job, worked fine not perfect, but you never see them unless making adjustments.
