Z1000 A1/A2 monoshock swingarm
Mick J
#1 PostAuthor: Mick J » Sun Jul 15, 2018 6:28 pm
Monoshock swingarm came with a Z1000 A2 frame I bought off ebay a few years ago. May be of use as is. Comes with a Spax shocker which I guess would need a rebuild. It was fitted cantilever style with a top mount welded to the frame which I couldn't save. It would be relatively easy to remove the top section and add shock brackets to use as a twinshock swingarm. It seems well made with substantial eccentric spindle holders (I don't have the wheel spindle) which are keyed for alignment and taper roller bearing at the pivot point. It is approximately 485mm between centres, dependant on the adjuster position. 50 quid collected if anyone is interested. I don't really want to post, but contact me if you want it but can't collect. Cheers Mick
Return to “For Sale”
