900a4 MC
sweptail
900a4 MC
#1 PostAuthor: sweptail » Mon Mar 24, 2008 6:42 pm
hi folks. Can anyone tell me if the clear sight plastic on my double disc master cylider separates from the ally. If so , how? Actually,im having it painted so i might be able to get away with masking off. what do you erudite z owners think. anyone know where i can get fork oil circlips from. Cheers Tommy
Padders
#2 PostAuthor: Padders » Mon Mar 24, 2008 6:53 pm
Mick took mine apart and fitted a new seal kit. There are two screws at the bottom of the site glass once taken out the plastic is still a very tight fit and needs a bit of brute to shift.
Hack
#3 PostAuthor: Hack » Mon Mar 24, 2008 8:46 pm
Yes, Padders is right. If you look inside there should be a perforated metal plate held in by two cross headed M5 screws. Remove these and the plastic body should twist out of the master cylinder.
You will need a new 'O' ring when you re-assemble the unit.
Cheers,
Andy
sweptail
#4 PostAuthor: sweptail » Tue Mar 25, 2008 9:36 am
thanks lads. tommy
