Does any one have as above for a 73 Z1
matching ignition and seat lock set with key please
that there willing to sell
many thanks
Z1 matching ignition and lock set
Re: Z1 matching ignition and lock set
Hi ac/dc
you can buy them new at Z-Power in the UK or in Germany at Z-Fever and at many other suppliers and they have the correct numbers on them.
Good luck!
Good luck!
Be aware though that they have the correct numbers on them and look correct but they aren't the same cut as the original so you can't get a key cut from just the number code
