Looking for a complete Points and Coils set up for (K)Z1000 A1 '77, preferably in the UK.
Must be loads out there for those that have switched to Dyna.
PM Me.
Original Coils and Points Plate
Re: Original Coils and Points Plate
I have the points and back plate £20 inc post
steve.w wrote:I have the points and back plate £20 inc post
ok cool, I'll pm you, if the offer I have at the moment for some doesn't come through. Thanks. Price is good too
Guy
- 8 Valve Mark
hi guy, I've got a pair of kawasaki tec coils (gpz 3ohm i believe) : they ran my a2 perfectly on points ignition, then i changed to dyna so kept them on the shelf.ht leads still attached n 3 outta 4 plug caps.£30 inc p+p cheers mark ps they'll need a good scrub
8 Valve Mark wrote:hi guy, I've got a pair of kawasaki tec coils (gpz 3ohm i believe) : they ran my a2 perfectly on points ignition, then i changed to dyna so kept them on the shelf.ht leads still attached n 3 outta 4 plug caps.£30 inc p+p cheers mark ps they'll need a good scrub
Thanks, same answer as before, I have some on the way, when I get my hands on them I'll be able to tell what condition they are in and will get back to you for sure. Will keep you in mind. thanks.
Guy
