Carbs Fcuking things
mikey
#1 PostAuthor: mikey » Wed Mar 26, 2008 8:26 pm
Im realy desperate to take my Z1000A2 to the ace on the 20th
but i have nothing but trouble with my carbs.
Start from cold ok but it starts by running on 2 or 3 cylinders,
leave it running on choke for a couple of mins and the last cylinder cuts in
or sometimes it dont and i gota clean the plug, when the last cylinder cuts in you can turn off the choke and start reving it, all the while this is going on its
backfiring and popping like a good un but when the last pot cuts in this also stops.
Anyway when you finally ride it, it pulls ok not thrashed it yet as i rebored the motor last summer still running in, but its not running right it feels rough.
Its running standard airbox/filter & jets exhaust is a bit iffy Harris down pipes
and collector box with a end piece that ash give me think its a piper or summat like that, balanced carbs best i could but im no expert at it. Done the
shims and checked the timing its running dyna s ignition and coils.
Any help much appreciated got me zzr 1100 to go on but i realy wanna take me Z :(
