Z1000 a2 rear brake piston
snowyz9
#1 PostAuthor: snowyz9 » Mon Sep 24, 2018 4:24 pm
Piston not moving out enough to apply brake , so need to blow them out , i know they could clean up but . Question ? are the aftermarket stainless item kits on e bay good quality
wheelysteve
Re: Z1000 a2 rear brake piston
#2 PostAuthor: wheelysteve » Mon Sep 24, 2018 4:43 pm
I've had pistons and seals from Powerhouse and they seem good quality. I've had no issues and will be rebuilding my Z1R brakes with their kits. They also offer an inhouse refurb service but I haven't used it.
https://www.powerhouse.uk/content/motor ... rvices.php
Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
#3 PostAuthor: chrisu » Mon Sep 24, 2018 4:54 pm
look at the ones on wemoto
snowyz9
#4 PostAuthor: snowyz9 » Mon Sep 24, 2018 5:22 pm
Thanks i managed to put out the hydraulic feed pipe side piston ,adjustment on foot pedal was wrong ,
all looks good and ive copper greased ,,,, Sorry more questions and thanks , should the opposing side piston also move , the side with the bleeder ? because its not
PAULJAC47
#5 PostAuthor: PAULJAC47 » Mon Sep 24, 2018 5:34 pm
If using hollow pistons be sure to use 9mm thick pads non sintered,if using solid type pistons with heat sink, you should use sintered 8mm thick pads,not a lot of movement on these back discs and you can end up with brake drag and over heat issues...
Users browsing this forum: No registered users and 97 guests
