Piston Liners Z1
DogsbolloxofZ1B
Piston Liners Z1
#1 PostAuthor: DogsbolloxofZ1B » Fri Sep 28, 2018 8:33 pm
Does anyone have a dimensioned drawing
of the std piston liner? I need to get a new set
and LA Liners are expensive so need to send
Westwood a drawing to get a quote.
Cheerd Mike
Re: Piston Liners Z1
#2 PostAuthor: z1bman » Fri Sep 28, 2018 10:59 pm
have you tried SEP ?
#3 PostAuthor: z1bman » Fri Sep 28, 2018 10:59 pm
8 Valve Mark
#4 PostAuthor: 8 Valve Mark » Sat Sep 29, 2018 12:37 am
mike, i recently did a Google search for "cylinder liners uk" or summit similar, it threw up various specialist companies willing to undertake small or one off orders, obviously providing an original as a pattern should negate the f'up risk.keep us all posted if you have a result eh? cheers mark
DogsbolloxofZ1B
#5 PostAuthor: DogsbolloxofZ1B » Sun Sep 30, 2018 12:26 pm
Have I used SEP?
Yes a few years back and I ended up with
a block weighing 3x as much as they got
something wrong and had to bore the block &
provide larger OD liners and to add to my
grief they forgot to put the chamfer on too.
I’m an eng so set up on a mill and did it.
Oh and the liners wouldn’t pass into too crankcase
so has to bore that too
Never again.
Big Fluff
#6 PostAuthor: Big Fluff » Mon Oct 08, 2018 9:10 am
I wouldn't go to SEP for a shite nowadays.
Their service is utterly and embarrassingly abysmal :x
#7 PostAuthor: Philippe » Mon Oct 08, 2018 10:46 am
Hi
take a look at this:
http://z-fever.de/shop/product_info.php ... 15ccm.html
maybe this could be helpfull...
#8 PostAuthor: ADRIAN H » Mon Oct 08, 2018 6:51 pm
#9 PostAuthor: z1bman » Tue Oct 09, 2018 8:49 pm
if you are replacing the liners why dont you measure them when they are removed from the cylinders
johny brando
#10 PostAuthor: johny brando » Fri Oct 12, 2018 1:19 am
DogsbolloxofZ1B wrote:Does anyone have a dimensioned drawing
Cheerd Mike
Hi Mike .What about just buying another set of S/H std liners = very easy to swap them over... 30mins @ 125 c in the oven = & they fall out ! or S/H complete barrel assy and have them honed if there OK ....or rebored to first oversize if there not ( Ebay USA seem to have em cheap quite often ..but P & P there is now outrageous ! ) ! best try & find them in the UK aye !
I bought new Std size L.A .Liners once and they still had to be bored & honed !!! yeh, they didn't arrive the finished size.. now where near ....I couldn't believe it ...what an arse ache & rip off !!! Good luck bud .
