z1 tank
z shed
z1 tank
#1 PostAuthor: z shed » Sat Sep 29, 2018 12:02 pm
Hi Can anyone tell me if a z1 tank has a dating code on it and where ?? photos would be good !!
garyd
Re: z1 tank
#2 PostAuthor: garyd » Sat Sep 29, 2018 12:05 pm
No dating code.
Look on the Zpower site to see the differences between models
Re: z1 tank
#3 PostAuthor: Philippe » Sun Sep 30, 2018 4:29 am
Hi Z shed
the Z1 tank looks the same as a Z1A or Z1B tank.
They all have the weldseam on the inside at the bottom.
The original Z1 tank has 122 mm between the two screwholes where the Kawasaki sign is attached , the Z1A and Z1B tank have 140 mm between the two screwholes.
I've seen some codes on the underside of some Kawasaki fuel tanks where the hook for the rubber band is attached but I have no idea what that code means. :?: That code is embossed in the metal and becomes visible when removing the paint to the bare metal. :shock:
Users browsing this forum: No registered users and 129 guests
