Re front Disc
snowyz9
Re front Disc
#1 PostAuthor: snowyz9 » Tue Oct 23, 2018 12:20 pm
Are you better off having 2 of the thicker usa single disc , on a twin front brake setup ? just thinking , extra weight is disadvantage , but i remember my last z1000 a1 twin front disc had such a squeal , would this be avoided with twin thicker disc ? also whats the best pads to use
Re: Re front Disc
#2 PostAuthor: ADRIAN H » Tue Oct 23, 2018 12:44 pm
I do nt think it makes any odds, as long as both discs are the same thickness ?
Pads - EBC Bike Brakes Kevlar Organic Pad (FA033) - for Z900A4 and Z1000A1 / A2
PAULJAC47
Re: Re front Disc
#3 PostAuthor: PAULJAC47 » Tue Oct 23, 2018 3:55 pm
Got the 7mm discs on a z thou,using organic pads works a treat,though it does weigh heavy...
Re: Re front Disc
#4 PostAuthor: Ultim8pc » Wed Oct 24, 2018 11:52 am
If you use the thicker discs I think you need some stronger front fork springs to handle the extra unsprung weight?
snowyz9
Re: Re front Disc
#5 PostAuthor: snowyz9 » Thu Oct 25, 2018 8:19 am
Thanks Guys
