Seen a lot of discussions about stem seals and gasket sets.
Normally buy from zed power,but some items can be very expensive.
Looking at a top end rebuild new pistons,rebore,valve stem seals.
Seen these on ebay
Kawasaki Z900 7mm Viton Valve Stem seals set of 8. The best! 362100452380
are these any good.
z1A VALVE STEM SEALS
Re: z1A VALVE STEM SEALS
they should be fine
I use Viton ones and not had a problem
