Garage Clear out - Z1000A1 Job Lot - The good the bad and the ugly!
csx355
#1 PostAuthor: csx355 » Thu Nov 22, 2018 12:21 pm
Hi all - given that my Z1000 has now transformed into a garage full of 1960's Norton's and BSA I need to make some shelf space. So I am clearing everything that I had that was remotely Z related. Please check the pics out. The tank is either a Z650 or a Custom it has a small dent - the fork stanchions are the original z1000 and pitted with rust but not beyond re-chroming. There are two air box's but tbh I do not know which model they are from they came with the bike. There is also a new fibre glass rear mudguard and a tail piece that needs some work. There is a rear brake calliper that has been vapour blasted and a rear hub that needs the steel spoke retainer replaced. Spokes, speedos, rev counters engine plates and bolts. Brand new front and rear disc pads new wheel bearings a gear box cluster and selector fork. The seat base is rotten but the foam is good. New Stanley head lamp shell. Exhaust collets, original scruffy fasteners need plating etc etc etc.
I would like it to go in one drop if possible, I can pack it and courier it to you UK mainland all up at £325 if any one is interested.
Keefleaf
Re: Garage Clear out - Z1000A1 Job Lot - The good the bad and the ugly!
#2 PostAuthor: Keefleaf » Thu Nov 22, 2018 3:57 pm
I could use the Z1000 rear hub,Cush drive rubbers & sprocket carrier....would you sell separately ?
csx355
#3 PostAuthor: csx355 » Thu Nov 22, 2018 10:04 pm
Hi Keef thanks for checking out my post I would prefer to clear the lot in one go - you could always make me an offer for the lot
Keefleaf
#4 PostAuthor: Keefleaf » Thu Nov 22, 2018 11:34 pm
I'll have a think :jake
Keefleaf
#5 PostAuthor: Keefleaf » Sat Nov 24, 2018 2:10 pm
P.M. Sent
csx355
#6 PostAuthor: csx355 » Sat Nov 24, 2018 8:25 pm
Thanks Keef - I'm happy with that - I have pm'd you back.
csx355
#7 PostAuthor: csx355 » Sat Nov 24, 2018 8:36 pm
8 Valve Mark - pm sent.
Return to “For Sale”
