For sale Tokiko 5/8 triangular master cylinder, body re/sleeved in stainless steel, new piston, seals, spring, grommet, new seal between body and reservoir, diaphragm in perfect condition, has a scuff on one corner of lid, has been tested overnight with lever pulled in using Dot 4 and no leakage at all.
Z 1000 triangular 5/8 master cylinder
