Z1000A2a Vacuum fuel tap
Just developed a leak from just above the bottom outlet , i renewed the pipe on bottom , thinking it was that , and the top fuel out seems dry around , Question do these petcocks develope leaks behind where you turn the fuel to prime etc , and is a new petcock the only way to go , re age
Re: Z1000A2a Vacuum fuel tap
There is a replacement kit you can buy.
http://www.nrp-carbs.co.uk/shop/index.p ... ct_id=3132
Gus
Gus
"Set the GRINDER on it"
