Hi all, not been on for a while.
Does anyone on here know the basic setup for the above carbs please?
Need to know jet sizes & needle type with a standard 1015 motor.
Thankyou
CR Keihin 29mm carbs
- stephen parr
Phil Churchett Award Winner 2012 (Z1R)
Phil Churchett Award Winner 2023 (Z1B)
PaulMceleney
- Chunks
Re: CR Keihin 29mm carbs
Hi Steve I have most jets if you want i could come over to you and see what works best if this helps
- stephen parr
Thanks for the offer Paul, but the carbs arn't mine, they're Geoff's mates in Lancs.
I have 29s on my 1015 motor ... 115 mains and it runs perfect
- stephen parr
Thanks very much Chris.
No, but "Hi Steve", great to see you're still around
Will
Will
From greg copes ape tuning guide.
CARBURETORS
Carburetors
For those of you running 29 smoothbores on a mildly modified street machine, here are some suggestions for carb modifications to give better mid-range performance:
# 20 Pilot Jets
# 0-4 Needle Jet
# 1.0 Air Jets
# 2.5 Needle & Set
* Float level heights, base of gasket to top of float 23.5 - 24.5mm
CARBURETORS
Carburetors
# 20 Pilot Jets
# 0-4 Needle Jet
# 1.0 Air Jets
# 2.5 Needle & Set
- stephen parr
Big Fluff wrote:No, but "Hi Steve", great to see you're still around![]()
Will
Thanks Will, hope to get back on the scene sometime next year.
- stephen parr
KWACKERZ1 wrote:From greg copes ape tuning guide.
CARBURETORS
Carburetors
# 20 Pilot Jets
# 0-4 Needle Jet
# 1.0 Air Jets
# 2.5 Needle & Set
Thanks very much Phil, VERY informative!
