Z1 -Z900 Rear wheel hub
DogsbolloxofZ1B
#1 PostAuthor: DogsbolloxofZ1B » Sun Dec 16, 2018 4:41 pm
Does anyone have a good rear wheel hub for sale?
The Steel liner needs to be in good nick and not cracked
like one I just bought recently off fleabay :(-
Mike
8 Valve Mark
Re: Z1 -Z900 Rear wheel hub
#2 PostAuthor: 8 Valve Mark » Sun Dec 16, 2018 10:39 pm
hi, mike can't it be welded n ground back? failing that paypal will refund you instantly, as it was damaged. i think i know the hub in question: crusty resto job with rust; welded bearings? i made an offer based on the work required n got turned down so i left it. i hope you get a result either way mate. m
