A bit more clearing out
Used Dyna S ignition with rotor and instructions - I bought this for an engine I never built off Phil Churchett when he was having a clear out years ago. I haven’t used it but have no reason to suspect it doesn’t work and I don’t want to pull mine off just to check. Missing one bullet connector which I’ll replace before posting. If it turns out doesn’t work send it back I’ll refund with postage. £70 plus post? DYNA PROVISIONALLY SOLD
Set of serviceable mini indicators with smoked lenses. These are chromed plastic in ok shape( need a polish) with small carbon brackets - with a bit of digging I’m sure I can find a picture somewhere of them on the bike if anyone wants to see that. Might be a bulb or two missing. £20 ono + post
Z1000 J R and GpZ rocker cover. Clean. No emission vents I think some US ones have?£40 + post? CAM COVER PROVISIONALLY SOLD
Dyna S and mini indicators
Re: Dyna S and mini indicators
I will take the DYNA S please Chris.
Sent you a PM
Sent you a PM
ANZed wrote:I will take the DYNA S please Chris.
Sent you a PM
Thanks Andrew. PM answered.
Chris, Can I have the rocker cover please
