Hi ,,,, I have the chance to buy the C5 ignition system for my Z1B which is fitted with a DYNA
At $300 it seems pricey compared to a DYNA but the kit comes with coils so thats ok
I asked them what the advantages of the C5 are over the Dyna and this is the reply
" C5 uses optical trigger with 180 references per revolution (180 times more than Dyna), it has more efficient coils with far more voltage, and it's made in the USA. Plus multiple sparking has shown to provide 8-12% increase in rear wheel hp on dyno tests.This is a small basic ignition that has one "factory" type timing map (not the 4 map version we normally offer "
1) Far more voltage ..How is that helpful
2) 180 references per revolution ....... Is that an advantage ?
3) 8-12% increase in HP ....... surely a pipe dream ?
Your thoughts would be appreciated before I spend any cash
C5 Ignition
Re: C5 Ignition
As you say - cannot see that sort of gain in power - even the points ignition must burn most of the fuel?
Optical ignition is okay, but needs to be set in darkened surrounds usually - like the old Pirahna (Newtronics) systems.
Dyna is proven technology & works well.
Re: C5 Ignition
chrisw1 wrote:Hi ,,,, I have the chance to buy the C5 ignition system for my Z1B which is fitted with a DYNA
I assume I second hand as on their website the big Zed setup is $479 and with the pound being what it is that’s a good bit... even more if you add import duty, vat and fees
Re: C5 Ignition
chrisNI wrote:chrisw1 wrote:Hi ,,,, I have the chance to buy the C5 ignition system for my Z1B which is fitted with a DYNA
No thats a new one , they are offering them at a discount if you do photo feedback
Re: C5 Ignition
Still duty and vat would bump it up a good bit...
- 8 Valve Mark
Re: C5 Ignition
+1 as already mentioned chris ; also worth considering is the fact that electronic parts are generally not refunded after sale. .possibly worth looking closer to home.. good luck mark
