Z1000 A2 Speedo cable
Wheres the best place to buy a decent cable , the ones advertised on e bay are the wrong size wheel end , and the one i bought from an internet multi classic parts supplier , lasted half a mile , before squeeking and then braking
Re: Z1000 A2 Speedo cable
I have an A2 for over 5 years now
I have not bought a speedo cable but I have replaced the push / pull accelerator cables from Wemoto - quality seems good.
You have to be careful with the A2 cables as the uk bars are lower than other models
If in doubt talk to ZPower - I have used since 1986 - extremely knowledgeable and very helpful.
Z1 Enterprises in the USA are also good.
There are lots of other suppliers, but these are my main ones.
010
Kev , Mines a Kz with higher bars , After the fiasco with them e bay ones and the wrong fitment wheel end , i did buy the one that broke from wemoto , it lasted a mile . Thanks for info , i will contact Phil at z power . i dont think i have put the drive in wrong ? and is where it should be , and it would have broke straight away if not geared
King of Kings
Just buy genuine Kawasaki cables?
Speedo cable is not affected by handlebar height.
kev edwards wrote:Speedo cable is not affected by handlebar height.
Correct. The length difference on A2 is due to re positioning the caliper behind the fork. Correct length is 94cm
ZedHead wrote:kev edwards wrote:Speedo cable is not affected by handlebar height.
Correct.
