Some more Bits'N' peices
Photos after the List
Offset Sprockets:- one is 528/17 Not sure how to work out the offset but is 1" face to face.
2nd one appears same offset but teeth are thicker 630? £25 each both are unused.
Z900 black front hub £25 Posted
Z900/Z100 headlight ears £30 posted..............................................................SOLD
Chrome Bottom yoke shrouds £14 posted
Fuel taps (4 injection type £12 posted) (1 z900 no vacuum and 1 later long 2 bolt fixing £20 the pair posted)
2 taps fitted to my Harris from years ago £25 posted
Fuse box ..not melted £18 posted
Z1000 regulators unused but untested £25 each
Connector panel with connectors £14 posted......................................................SOLD
L/H swiches repro £20
L/H switches original but needs refurb £13........................................................SOLD
Battery lead positive £10
Z1 type seat post ( No idea how or where these came from ) £8 each..........................ONE SOLD
Kerker oil cooler with braided hoses £80 plus postage............................................SOLD
Set of shim over buckets (finally found them!!!) £20
Points plates£5 each
Plastic battery box £8
Fuel cap original £10
Sprocket covers (1 Z900 £15, 1 MKII) £15 each....................................................Z900 ONS SOLD
Yokes £15 each.........................................................................................ONE PAIR SOLD
Foot reast £5 each.....................................................................................ONE PAIR SOLD
Short indicator stalks repro £12......................................................................SOLD
Manual camchain tensioner £25
1100 DOHC side panel badge £8
4 hole front hud with cast iron discs and carriers ( discs not in photo) £75
Speedos/ tachos/ Brackets/ idiot light covers of various quality PM me for more info...MOST OF IT SOLD
Re: Some more Bits'N' peices
PaulMceleney
- Chunks
Pm sent
Hi Gary
PM sent.
PM sent.
- 8 Valve Mark
z900 sprocket cover and a pair of footrests please gary. if still available?cheers mark
Hopefully I've PMed everyone
HighlandStu
- Regular Poster
PM Sent, I'll take the connector panel if still available
Stu
Stu
Z900 sprocket cover still available? If so I'll have it. Buzzard.
Every man should have a shed (for bikes obviously..)
buzzard wrote:Z900 sprocket cover still available? If so I'll have it. Buzzard.
Sorry...beaten to it
garyd wrote:Photos after the List
Sprocket covers (1 Z900 £15, 1 MKII) £15 each.........................Z900 SOLD
Yokes £15 each
Foot reast £5 each.......................................................One pair SOLD
Speedos/ tachos/ Brackets/ idiot light covers of various quality PM me for more info. ....................Some clocks SOLD
P1090423.JPGP1090424.JPGP1090425.JPGP1090426.JPGP1090427.JPGP1090428.JPGP1090429.JPGP1090430.JPGP1090431.JPGP1090433.JPG
Hi See PM- Speedo and Tacho if still available
garyd wrote:Hopefully I've PMed everyone
Pm replied to.
Pm sent
