13 row Oil cooler mounting bracket original produced by the now defunct KipKawa. Replica of the bracket used by Kawasaki on the Z1000S. Bolts to where the horn bracket attaches to the frame. Holds standard size 13 row cooler (Earls, Mocal etc). Virtually new. I fitted it then changed my mind and used a Tomforde version of the same thing. Slight flaking of surface finish on the top mount but otherwise A1.
I think this was close on £80 new so I think £40 plus post is fair.
Kipkawa Z1000S Lawson Oil Cooler Mount
martinz1000r
Re: Kipkawa Z1000S Lawson Oil Cooler Mount
Yes please Martin.
can you pm me payment details
Gus
Gus
"Set the GRINDER on it"
martinz1000r
Gus wrote:Yes please Martin.
Gus
Will do Gus! Will be later this evening
