Trying to push out the rear wheel bearings using a press and plenty of heat...pushing from the outside in, big socket on outer race then the 20t press, moved a bit but that's it...don't want to break anything.
Opinions please.
Ady
Rear wheel bearings
Re: Rear wheel bearings
pushing from the inside out sounds better to me
Zeds-R-Us
- 8 Valve Mark
+1 to the inside outwards method.
Will try, thanks
1st catastrophe of the refurb...centre hub shattered when pressing out the bearing despite loads of heat. Bollocks!!!
Can you still get these?
Ady
Ady
- 8 Valve Mark
OUCH!! the good thing is it hasn't let go at speed on the road...someone here will have a spare hub.. cheers m ps any pics?
No pics Mark...million bits in works skip! Centre hub anyone?
