z1000 Torque arm
steve bowdler
z1000 Torque arm
#1 PostAuthor: steve bowdler » Sat Jan 05, 2019 5:48 pm
Hi is there any difference between the torque arm on the z1000A1/2 and the B1/2 models ? , I know the swing arm is shorter !
Re: z1000 Torque arm
#2 PostAuthor: z1bman » Sat Jan 05, 2019 6:12 pm
yes its shorter & different part no
steve bowdler
#3 PostAuthor: steve bowdler » Sat Jan 05, 2019 6:46 pm
Ok thanks , then could someone post some measurements of a z1000 a1/2 torque arm please
RGH
#4 PostAuthor: RGH » Sat Feb 02, 2019 4:53 pm
steve bowdler wrote:Ok thanks , then could someone post some measurements of a z1000 a1/2 torque arm please
370mm overall
340mm centre bolt holes
#5 PostAuthor: chrisu » Sat Feb 02, 2019 10:15 pm
Do you need one Steve?
steve bowdler
#6 PostAuthor: steve bowdler » Thu Feb 07, 2019 9:49 pm
not sure yet Chris , I believe I have the shorter z1000 b2 swing arm but think I have the standard torque arm ?? will re measure this weekend
8 Valve Mark
#7 PostAuthor: 8 Valve Mark » Thu Feb 07, 2019 11:20 pm
I've got a spare ltd one if you want one steve.i can measure it if you need one. m
steve bowdler
#8 PostAuthor: steve bowdler » Fri Feb 08, 2019 8:24 pm
Hi, yes if you could measure it please :D
8 Valve Mark
#9 PostAuthor: 8 Valve Mark » Sat Feb 09, 2019 8:14 am
350mm,hole centres@ 320mm
Users browsing this forum: No registered users and 81 guests
